- Accessing old floppy disks (Gen:2)
- Aemulor Pro-gress
Know your enemy
The source
The destination
The tools
  • ffmpeg
  • toolame
  • Perl
  • mpgtx
The process
  6. Delete the temporary files
The script
The result
Q&A
A.
Q.What about Google Video?
Q.What about VideoCD?
Q.What about your Zaurus?
  ksattic (21:11 5/12/2006)
  Chris (14:14 6/12/2006)
      richcheng (10:50 8/12/2006)
          adrianl (19:16 8/12/2006)
ksattic
Finally, an avatar!
But otherwise: Yay!
